Hi all,
I am trying to create a floor (or slab) under an angle in Revit using Speckle in Grasshopper. I tried to use the Floor slopedArrow option in combination with the angle option. It seems that everyting I put in doesn’t connect to Revit as the floor that I created does not contain the slopedArrow nor an angle in general.
Does anyone know if it is possible to create a sloped floor/slab in Revit using Speckle and what is the way to go for this? Thanks in advance!
