Silent install for connector deployment
Hi!
Their may be a problem with the Silent functions. They are not possible…
I have done all combination of this parameters:
/ALLUSERS
/ACCEPTEULA
/SILENT
/VERYSILENT
/SUPPRESSMSGBOXES
/DIR=“C:\Program Files (x86)”
Hey @EngKarl ,
Which installers have you tried them with? Could you share how you are executing these commands?
In case you haven’t seen it before, here are the official InnoSetup docs: Inno Setup Help
I downloaded Speckle as descriped and i deployed already a lot of Inno Setups with Aagon ACMP before.
xxx.exe /PARAMTERS as descripted in all combinations. Maybe the EULA is blocking somewhat?
That is possible.
The commands above should work with each individual connector installer that can be obtained from here:
