Hello everyone, I want to see the total volume of the objects I selected by selecting more than one element/object in my model that I transferred to Power BI with Speckle, but when I select it now, I can only see the volume of the last one I selected. How can I do that ?
Merhaba Eray,
The issue you are facing is due to a limitation of Power BI’s visuals, as far as I can see. I have verified that this limitation is also present in the default visuals provided by Power BI.
For displaying the total volume of selected items, I suggest adding a Card to your dashboard instead of relying on the tooltip.
I hope this explanation helps clarify the matter.
My problem was solved when I removed the m2 and m3 texts and made the column decimal. Thank you for your support.
