Hello everyone, I want to see the total volume of the objects I selected by selecting more than one element/object in my model that I transferred to Power BI with Speckle, but when I select it now, I can only see the volume of the last one I selected. How can I do that ?
Merhaba Eray,
I would be happy to help. Could you please share the URL of the Speckle model so I can investigate? You can send it privately if you prefer.
After taking a look at the issue, it seems like the limitation you’re facing is actually related to Power BI, rather than our visual.
To get the total value you’re looking for, I recommend adding a Card visual and connecting the field to it. This should solve the problem and get you on your way.
