Sending text from Grasshopper
Hey @davidjbrownstein ,
Grasshopper can only bake and not output TextObjects/Rhino.Geometry.TextEntity. There are some plug-ins around that let you output or convert grasshopper text to Rhino.Geometry.TextEntity. For example you can use Fennec and convert your text to Rhino Text. Then you can use the Speckle Dev Component “To Speckle” to convert the Rhino.Geometry.TextEntity to Speckle Text.
Show Dev Components
