Sending text from Grasshopper
Hi all,
Is there a way I can get text to the Speckle viewer? At the moment when I send my analysis results from grasshopper directly to the Speckle viewer everything comes across nicely except the text which doesn’t appear.
Hi @davidjbrownstein
The speckle viewer currently supports text, however not universally from all host apps. It’s currently mostly restricted to text coming from Rhino and Autocad and it does not try to exhaustively support all the text features. For example this stream has some text and measurements coming in from Rhino
Maybe @clrkng has a better idea if text coming from grasshopper could currently make it to the viewer. And if so, how.
Cheers
Hey @davidjbrownstein ,
Grasshopper can only bake and not output TextObjects/Rhino.Geometry.TextEntity. There are some plug-ins around that let you output or convert grasshopper text to Rhino.Geometry.TextEntity. For example you can use Fennec and convert your text to Rhino Text. Then you can use the Speckle Dev Component “To Speckle” to convert the Rhino.Geometry.TextEntity to Speckle Text.
Show Dev Components
Thanks both for the replies. I’ve taken to baking the text onto layers in rhino and then sending them to speckle that way. Everything works as expected.
