Sending from Revit is too slow
Now I have problems to use the Revit Connector :o. A lot of time to send a single family :(. There is some update to do?
Hi @mirko.maccarronello ,
How are you sending the geometry? Are you sending from Project environment or Family environment. Sending from family environment is a bit problematic currently. If you are sending from family, can you try loading it to a project, select it and send it to Speckle?
It would be great if you could also share this family with us so we can see how complex it is :slight_smile:
Yes by family environment. I try by project. Thanks
It’s run by project and tempalte. Thanks @gokermu
