Sending from connectors fails in custom server
Hello!
I’ve created a private server following the docker instructions. Everything is working well (I can create projects, models, the connectors read the server, etc), but I having a problem sending information to the server. I tried sending some info from Rhino and from Revit and according to the log it’s seems like the error is the same.
Rhino - SpeckleCoreLog20240708.txt (34.3 KB)
Revit - SpeckleCoreLog20240708.txt (20 KB)
What could be the error?
Is there any meaningful error in the Server Log that you could point us to?
@teocomi Thanks for the response. Where I can find the server log?
Hi @efdiloreto
Assuming you are running via Docker Compose and are using Docker Desktop, you will find instructions on how to retrieve the logs here: Explore the Containers view in Docker Desktop | Docker Docs
You will need to view the logs for the speckle-server container.
Hope this helps,
Iain
Amazing, thanks! Missed that part when I read the docs.
@efdiloreto this looks like your server doesn’t have enough resources. What type of machine are you hosting this on?
I think you are right. IT department created a server with limited resources. Will try to change the server and see what happens.
Hello again!
I’ve managed to get the log so I’m attaching it here. I think the error is around the line 1021.
One more comment, when I send geometries like points and lines it doesn’t fail. It fails when I try to send a surface (for example one simple Rhino planar surface created from a rectangle) or more complex objects.
Docker log.json (36.5 KB)
