Hi, just installed and testing it
I have succesfully sent a mesh stream from Blender and shows up in Speckle but when i try to receive it into Grasshopper, nothing appears and no errors neither.
Is this supported yet?
Hi! can you post a screenshot of your grasshopper definition? There might be some object unpacking that @izzylys & @AlanRynne could help you with!
Hello
Indeed think i managed to fix it by adding an Expand Speckle Object. But Is it always required for Blender? I see that for Archicad it doesnt. This is the definition which works.
@Constantinesis, it might help to let us know which version of the plugins (Grasshopper & Blender) you are using if the problem persists!
PS: if the stream is not sensitive, share it with us here so we can debug locally.
@dimitrie I am using plugins version 2.6.0 for Blender and 2.5.2 for Grasshopper
Here is the stream, its just a cube, i am testing.
I tried again and it only shows up when usign the ESO component.
I think i understand what it does. It sends the collection and the selected object as a hierarchy so it needs to further point to the object.
Not sure why in @gokermu sample its just the object alone
In my case i selected the objects and sent them. That might be the reason
I did the same, selecting then send. I dont think you can send without selecting?
