- Objective: I want to send specific 3D View to specific branch from my own plugin.
I am implementing a plugin to automatic, divide my project into relevant group of elements and create a 3D View for each group.
Once this division is achieved, I am sending from the Plugin this 3D View to the speckle server.
- Issue: The code is working fine, for most of the cases, getting a lot of help from the implementation in ConnectorBindingsRevit.Send.cs, I am successfully finding the elements in the view, converting them to speckle objects, create the Branch in case does not exist yet and send them over to Speckle. BUT there an error that appears when trying to send stairs.
I’m having hard time to solve this because is just happening with the stairs so far, which seam weird, but I do not know… Maybe this is not the most optimal implementation. Here is a screenshot of the error, the description and the function.
Thanks again for any clue in how to solve this!
Error → Speckle.Core.Kits.ConversionSkippedException
HResult=0x80131500
Message=StairsRun are handled by the Stairs conversion
Source=Objects.Converter.Revit2024
StackTrace:
at Objects.Converter.Revit.ConverterRevit.ConvertToSpeckle(Object object)
at TopBimManager.Events.SpeckleConnector.d__4.MoveNext() in C:\Users\jairo.picott\source\repos\TopBimManager\TopBimManager\Events\SpeckleConnector.cs:line 63
This is the function that send the data to speckle
public async void SendViewToSpeckle(UIApplication uiApp, View3D view)
//To Get from UI
//Hardcoded for DEBUG
var streamId = "518eadde6b";
var branchName = view.Name;
//End To get from UI
//Get account data
var defaultAccount = AccountManager.GetDefaultAccount();
var client = new Client(defaultAccount);
var transport = new ServerTransport(defaultAccount, streamId);
//Load Converter
var kit = KitManager.GetDefaultKit();
var converter = kit.LoadConverter(Objects.Converter.Revit.ConverterRevit.RevitAppName);
converter.SetContextDocument(uiApp.ActiveUIDocument.Document);
var docProvider = new UIDocumentProvider(uiApp);
var cache = new RevitDocumentAggregateCache(docProvider);
converter.SetContextDocument(cache);
//Collect Elements to send from the View
FilteredElementCollector c = new FilteredElementCollector(uiApp.ActiveUIDocument.Document, view.Id);
var selection = c.WhereElementIsNotElementType()
.WhereElementIsViewIndependent()
.ToList();
//Process the selected elements and convert to Speckle Base
converter.SetContextDocument(view);
selection = HandleSelectedObjectDescendants(selection).ToList();
converter.SetContextObjects(
selection
.Select(x => new ApplicationObject(x.UniqueId, x.GetType().ToString()) { applicationId = x.UniqueId })
.ToList());
IList<Base> speckleObjs = new List<Base>();
foreach (var item in selection)
if (converter.CanConvertToSpeckle(item))
speckleObjs.Add(converter.ConvertToSpeckle(item)); //Line that throw the Exception
//Create Commit Object and add the Speckle Base Objects
var commitObject = new Base();
commitObject["name"] = view.Name;
commitObject["children"] = speckleObjs;
//Send commit object to transport
var hash = Operations.Send(commitObject, new List<ITransport> { transport}).Result;
//Check if Branch exist, if NOT create new branch
var branch = await client.BranchGet(streamId, view.Name.ToLower());
string branchId;
if (branch == null)
BranchCreateInput bci = new BranchCreateInput();
bci.streamId = streamId;
bci.name = view.Name.ToLower();
branchId = await client.BranchCreate(bci);
//Create the Commit
var commitId = client.CommitCreate(new CommitCreateInput()
branchName = branchName.ToLower(),
message = "Created from TBM",
objectId = hash,
streamId = streamId,
sourceApplication = "TBM"
}).Result;
//Dispose the Client
client. Dispose();
