SectionTool not working at viewer version 2.25.4
The SectionTool extension seems not to be working in viewer version 2.25.4 (havn’t checked all the versions). Last version I used and it was working is 2.23.1
As you can see in this link that I just copy from the example from the doc and changed viewer version.
There is no error message or anything and I havn’t dig into the code. so I cannot say what’s the problem.
Hi @maipatana
Indeed, this is an oversight on our part after the last iteration on the section tool. This will get fixed in the next release, but until then as a temporary measure you can replace SectionTool with OrientedSectionTool in createExtension
Cheers
Hi @maipatana
Following up on this, starting with 2.25.7, you can refer to the section tool extension as SectionTool like before and everything should be fine
Cheers
Thank you for the update.
