Hi, may I ask a bit about this topic?
I am trying to build and run speckle on Window Server, what I’m trying to do is build every project (server, frontend-2,…) and host it on node environment on server.
When I try to build frontend-2 with “yarn build”, I also get the error described in this topic. Is there any way to resolve this error :< ?
hi @P_Agent
Unfortunately we don’t support Windows as a development platform. You will need to either run it under a Unix-like OS, or under WSL if running Windows.
Cheers
Hi, thank you for your quick response.
I’m sorry in advance for my little experience in Vue, but as I understand, I can build the project and host it on node environment, similar to React/Nextjs, right? What i’m trying to do here is build the frontend-2 project, but I get build error :<<
May you explain can I do that or not? Thank you.
Hi @P_Agent, we won’t be able to help you here, unless you instal WLS2 and clone the repo in that environment.
