It seems to be related to Serilog dependencies, so I’m not sure how can I resolve the underlying issue. I ran into this using a local clone of your main branch (I’m also experiencing the same issue with the Arup fork).
Has anyone from your team experienced this? If so, was there a workaround to produce a new SchemaBuilderGen.cs?
The T4 generation has been, indeed a bit of a hit and miss. Try deleting the obj and bin folders of all projects in the solution and do a full rebuild… @AlanRynne might have other tricks under his sleeve.
FYI @AlanRynne I did also try running the command with extra cmdline arguments (similar as set up in ConnectorGrasshopper csprojs) but encountered the same issue
