Hi all,
I am quickly trying to send some stuff from Rhino to Revit, just some lot curves which are fine in rhino but when I import them to revit they get broken up into tiny segments which is so hard to manage. Any way around it?
Hi all,
Hey @Rivindu_Bandara ,
Revit has no concept of Polylines. So when you send polylines/curves from Rhino, they’ll get individually selected in Revit. This is the expected behaviour.
Can I ask what are you going to do with those curves in Revit?
Hi @gokermu,
Thanks for that clarification, I myself don’t need the curves in Revit but our architects at our firm do preferably as Model Lines or something similar. I’m assuming the lines just have to be there as reference, I have used Rhino Inside as a temp fix to send them as direct shapes and that works fine but I personally prefer having a speckle workflow around this if there is something available.
We are going to add support for sending Curves and Points as DirectShapes in 2.15 (hopefully🤞).
Hi @gokermu
Curves sending as Direct shapes works really well in the new update. Great work team!
