I am a little confused after uninstalling the speckle manager it seems I no longer have access to speckle schema tool? Is there a new way to share rhino to etabs now?
Thank you for seeking help! Our friendly community is here to assist you. ![]()
Speckle Status: Please check that our systems are up and running: https://status.speckle.systems/
Objective: What are you trying to achieve, e.g. Receive Blender data in Excel, Use REST to query comments, …
Issue: If you suspect a bug, describe what you expect to happen. Explain what is happening or failing to happen. If you instead need a guiding hand, where are you stuck?
Example: Help us reproduce the issue by attaching sample files, giving a step-by-step reproduction guide and screenshots/videos if available
Speckle link: What better way to share data than using Speckle?
Logs: If the issue regards our desktop connectors, please share the relevant logs you find under:
%appdata%/Speckle/Logs
