Rhino to blender, weld mesh + origin point
-I recently started to use speckle between rhino and blender (mostly rhino to Blender)
but each time I import a model from rhino to blender, each face is not joined, I need to mannually merge by distance the mesh. Is there a way to automatically weld the mesh?
-Also when I export a selected geometry I can’t specify an origin point, the origin point being the center of the file,
Thanks in advance,
Hey @Paul ,
Don’t Clean Mesh option does what you want?
Hi Gokermu,
Thanks that work! Anything about the changement of the origin point?
Should I introduce myself in this thread?
Thanks,
We are using the origin coming from Rhino. Changing the origin point hasn’t been asked before. What is your use case?
You can introduce yourself here :person_gesturing_ok: if you want to! :grinning_face:
