Hi @du5aIV
After having looked into this a bit more, I can now provided a little more context on exactly what has changed r.e. updating objects within the blender connector.
In versions of our Blender connector before version 2.16, the “update behaviour” was some logic within the receive operation that would deleted existing Collections (by name) if they were found in the new receiving commit.
The problem is, Blender has the requirement that no two collections are named the same, but this assumption doesn’t hold true for data sent from most of our other connectors, and as such, it was leading to situations where, within a single receive operation, we were deleting objects within similar named collections. (see issue)
This would result a very buggy experience, frequently many objects would be missing after a receive operation, and any other collections the user had in their file that happen to collide in name with something they were receiving also be deleted. All while giving the user zero warning. ![]()
This was becoming a bigger and bigger problem, because around this time, we were implementing support for collections in more and more connectors.
Additionally, based on some user feedback, several users said that they would prefer a completely non-destructive receive mode, where we simply create data and not destroy or mess with any of the data in the users scene (like a file import).
We made the decision that having a robust and reliable “create only” receive mode would be better than the existing buggy and inconsistent update mode that would occasionally delete users data erroneously. And in this patch, we changed to the behaviour we have now; a non-destructive receive that only creates objects & data.
However, we do understand the need for an update mode. And to do this properly, we would be looking to do something similar to our Rhino connector, where we have a separate “create” and “update” modes.
We have this feature request tracked, but needs some more designing before we can start development. I’ll keep you updated on any progress, but right now I can’t give you any timescale on this.
Of course, version 2.15 of our connectors are still available, although please aware of the aforementioned problems, and they may be unable to receive data from newer versions of other connectors.
We’ll try and communicate these sorts of breaking changes better in future, particularly as we aim for a more stable and reliable Blender connector.
Thank you for your patience.
