Rhino will hang and ultimately crash when I click the Speckle button on the toolbar, i’m signed in, so it’s not relating to this issue Rhino crashes when using Speckle - #11 by dimitrie
Crash log says:
[ERROR] FATAL UNHANDLED EXCEPTION: System.ComponentModel.Win32Exception (0x80004005): 配額不足無法處理此命令。
於 System.Windows.Interop.HwndTarget.UpdateWindowSettings(Boolean enableRenderTarget, Nullable`1 channelSet)
於 System.Windows.Interop.HwndTarget.UpdateWindowPos(IntPtr lParam)
於 System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
於 System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
於 MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
於 MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
於 System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
於 System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
[END ERROR]
配額不足無法處理此命令 can be translated to something like not enough allocation to execute command, sound like not enough RAM for something, but when viewed with task manager, Rhino is barely using any RAM.
Dump file is here:
This only happens on this one laptop I have, tried reinstalling both Rhino and Speckle, but still the same problem.
Any ideas?
