Hello!
I have a problem using the speckle rhino everytime I use the command speckle in rhino, the rhino freezes and crashes at the moment.
I’m using rhino 7.23 and Speckle 2.10.4
Thank You
Hello!
Thank You
Hi @Chanthearot_Bun ,
Can you please update to our latest release 2.12.2 and let us know if you still have the issues?
yes, the rhino still crashed even i use speckle v2.12.2
it always appears no stream found the moment i use speckle in rhino and then it freezes my rhino then it crashes.
Can you please send me the latest log file under %appdata%\Speckle\Logs\rhinoRhino7
in a PM?
SpeckleCoreLog20230305.txt (10.8 KB)
Here is the latest log file.
Thank you
Thanks! It looks like due to some connectivity issues, are you behind a corporate proxy/VPN?
Does any other connector work?
Are you using the speckle.xyz server?
Yes, im using speckle.xyz
Thanks for confirming. Could you please try with another connector like Revit?
It seems there could be a VPN or firewall blocking access to Speckle.
