Hi @Hussein_Hamed!! Welcome to the community!
Could you give us more details of how this happened?
what version of Speckle and Revit are you running?
if the rhino connector doesn’t work for you either, could you tell us which version you are running too?
did you change anything in your sistem before it started failing? (Updated speckle or Revit, etc…)
It would help pinpoint the cause of the issue.
As a last effort, could you try and uninstall and reinstall the connectors and tell us if that worked?
Thanks for reporting this, and feel free to Introduce yourself 🙆 to the community if you feel like it
I unistalled them and reinistalled them again
I have this messege before the installaion and i think this causes the problem
i’m using the version of speckle and revit 2021
Hi @Hussein_Hamed ,
If you close AutoCAD/Civil3D that message should go away.
Can you please also check if your antivirus might be flagging the installed software as malicious?
Thanks the problem has gone but I don’t care about autocad as I installed revit, grasshopper and rhino conncetor so I thought Autocad wouldn’t mind but he really cares
