Hi!
I got an invitation to Speckle v2 beta and wanted to test it out. When I got everything installed and tried to create a stream from Rhino 7, the program just crashes. Is this some kind of a known bug or what kind of information should I send you to figure out what the problem is?
Thanks,
Taavi
              Yikes! it’s not expected, or known. Usually Rhino writes a crashfile to your desktop (in text format) - is there any chance you could copy paste that here?
              Hmm, I figured out what is going on. Somehow the connection to the account was lost from the Manager, but I didn’t notice this before. And when I tried to create a stream, something must have failed and crashed the plugin. Now that I connected the Manager correctly, it works fine.
              Ah, so basically you had no accounts when you tried to create a stream? We’ll try that route. That’s something we can try debugging. We’ll post any updates here!
