Revit Wall and Window Object via SpecklePy
Hi @izzylys,
i ve watched your tutorial on how to create a revit beam via python. thanks!
  1. could you kindly extend your example and show how to create a Revit Wall and Revit Window object via SpecklePy?
  2. Could you provide a reference document of all attributes and types that exist in speckle and their
    parameters? e.g. Revit Beam, Revit Steel Beam, ArchiCAD Wall etc..
  3. Since you define the Revit Wall type here, are those types also understood by ArchiCAD?
  4. Im receiving the following error when executing the Script multiple times. Perhaps you know how to solve it too :slight_smile:
ValueError: The speckle_type: Objects.BuiltElements.Level is already registered for type: Level. Please choose a different type name.
At:
  C:\Users/Public/Documents/cadwork/USERPROFIL_30/3d/API.x64/kumiki\Lib\site-packages\specklepy\objects\base.py(174): __init_subclass__
  C:\Users\mhelmrei\Documents\GitHub\kumiki\src\kumiki\ui\main_window.py(82): <module>
  <frozen importlib._bootstrap>(241): _call_with_frames_removed
  <frozen importlib._bootstrap_external>(883): exec_module
  <frozen importlib._bootstrap>(703): _load_unlocked
  <frozen importlib._bootstrap>(1006): _find_and_load_unlocked
  <frozen importlib._bootstrap>(1027): _find_and_load
  C:/Users/Public/Documents/cadwork/USERPROFIL_30/3d/API.x64/kumiki/kumiki.py(28): <module>
Thanks a lot!
Matthias
we managed to go around question #4 with the following functions… but maybe not ideal.
cheers, matthias
def get_fully_qualified_name(cls):
    return f"{cls.__module__}.{cls.__qualname__}"
keys_to_remove = []
for key, value in _RegisteringBase._type_registry.items():
    print(key, value)
    if get_fully_qualified_name(value).startswith("kumiki"):
        keys_to_remove.append(key)
for key in keys_to_remove:
    stype = _RegisteringBase._type_registry.get(key)
    if stype:
        del _RegisteringBase._type_registry[key]
Hi @mhelmrei,
Sorry about late reply. Let’s go over your questions.
Unfortunately, I can’t provide you a document that shows all the classes Speckle has, but even better, I can provide you the source code. You can find all the types and attributes here.
For creating custom objects with Specklepy, using these references, I’ll attach some examples below.
Here how you can create a RevitBeam:
from specklepy.objects import Base
from specklepy.objects.geometry import Line, Point
from specklepy.api.wrapper import StreamWrapper
from typing import List, Optional
class Level(Base, speckle_type="Objects.BuiltElements.Level"):
    A custom Level class
    name: str = None
    elevation: float = None
    def __repr__(self) -> str:
        return f"Level(id: {self.id}, name: {self.name}, elevation: {self.elevation})"
class RevitBeam(
    Base, speckle_type="Objects.BuiltElements.Revit.RevitBeam", detachable={"level"}
    A custom RevitBeam class
    family: str = None
    type: str = None
    baseLine: Line = None
    level: Level = None
    units: str = None
    displayValue: list = None  # List[Mesh]
    parameters: Base = None
    elementId: str = None
        return f"RevitBeam(id: {self.id}, family: {self.family}, type: {self.type}, level: {self.level}, baseLine: {self.baseLine})"
# Create a level
level = Level(name="Level 0", elevation=0)
# Create a beam
beam = RevitBeam(
    family="Structural Framing",
    type="UB305x165x40",
    level=level,
    baseLine=Line(start=Point(x=0, y=0, z=0), end=Point(x=4, y=10, z=0)),
    units="m",
# Create commit object
commit_obj = Base()
commit_obj["@revit beam from python"] = beam
# Send to Speckle
wrap = StreamWrapper(
    "<YOUR_URL>"
client = wrap.get_client()
transport = wrap.get_transport()
obj_id = operations.send(commit_obj, [transport])
client.commit.create(wrap.stream_id, obj_id)
print(f"Successfully sent beam with ID: {obj_id}")
You’ll only see a base line in the viewer, but if you receive in Revit, this will create a Revit Beam for you.
And you can extend this logic to create other custom classes in python. For example to create a Revit Wall, following the same logic:
    name: str = None
class RevitWall(
    Base, speckle_type="Objects.BuiltElements.Revit.RevitWall", detachable={"level"}
    A custom RevitWall class
    family: str = None
    type: str = None
    level: Level = None
    height: float = None
        return f"RevitWall(id: {self.id}, type: {self.type}, level: {self.level}, baseLine: {self.baseLine})"
# Create a level
# Create a wall
wall = RevitWall(
    family="Basic Wall",
    type="Wall-Ext_102Bwk-75Ins-100LBlk-12P",
    level=level,
    baseLine=Line(start=Point(x=0, y=0, z=0), end=Point(x=5, y=0, z=0)),
    height=3.0,
commit_obj = Base()
commit_obj["@revit wall from python"] = wall
# Send to Speckle
    "<YOUR_URL>"
print(f"Successfully sent wall with ID: {obj_id}")
When you receive this stream in Revit:
These types are built for Revit, and not going to be native for ArchiCad. But Speckle object is dynamic, it’s up to you to extend it :slight_smile:
Hope this helps.
I’ll be here for further questions.
Dogukan
@dogukan Thanks for the reply. I was trying to query objects using the new Speckle Connector v3 in Revit and Archicad, but I wasn’t able to retrieve any native wall objects, except the base line. It works fine with the previous v2 connectors though. I also tried the v3-dev branch on specklepy.
Thanks a lot,
Matthias
Speckle project link:
Example code I’m using:
from specklepy.objects.base import Base
from dotenv import load_dotenv
import logging
import os
# Load environment variables
load_dotenv()
LOG = logging.getLogger(__name__)
logging.basicConfig(level=logging.INFO)
# Get config from .env
SPECKLE_HOST = os.getenv("SPECKLE_HOST")
SPECKLE_TOKEN = os.getenv("SPECKLE_TOKEN")
STREAM_ID = os.getenv("STREAM_ID")
# -- Speckle-Compatible Classes --
    name: str = None
class Wall(Base, speckle_type="Objects.BuiltElements.Wall"):
    family: str = None
    type: str = None
    level: Level = None
    units: str = "meters"
# -- Input Wall Format --
class CTWall:
    def __init__(self, p1: Point, p2: Point, height: float):
        self.p1 = p1
        self.p2 = p2
        self.height = height
# -- Conversion Function --
def create_wall_from_ctwall(ct_wall: CTWall) -> List[Wall]:
    level = Level(name="Level 1", elevation=0)  # Must match Revit level
    wall = Wall(
        family="Basiswand",
        type="Ziegel+WD hart 300+160",  # Must match a valid Revit wall type
        baseLine=Line(start=ct_wall.p1, end=ct_wall.p2),
        level=level,
        height=ct_wall.height,
        units="meters",
    return [wall]
# -- Commit to Speckle --
def send_to_speckle(ct_wall: CTWall, speckle_client: SpeckleClient, stream_id: str):
    walls = create_wall_from_ctwall(ct_wall)
    commit_obj = Base()
    commit_obj["walls"] = walls
    # Transport setup
    wrapper = StreamWrapper(f"{SPECKLE_HOST}/streams/{stream_id}")
    transport = wrapper.get_transport()
    try:
        object_id = operations.send(commit_obj, [transport])
        speckle_client.commit.create(
            stream_id=stream_id,
            object_id=object_id,
            branch_name="main",
            message="Cadwork: Sending wall element to Revit",
        print("âś… Wall successfully sent to Speckle stream:", stream_id)
    except Exception as e:
        LOG.error("❌ Failed to send to Speckle: %s", e)
# -- Main entrypoint --
if __name__ == "__main__":
    start = Point(x=0, y=0, z=0)
    end = Point(x=5, y=0, z=0)
    wall = CTWall(p1=start, p2=end, height=3.0)
    # Authenticated client
    client = SpeckleClient(host=SPECKLE_HOST)
    client.authenticate(token=SPECKLE_TOKEN)
    if not STREAM_ID:
        raise ValueError("Missing STREAM_ID environment variable.")
    send_to_speckle(wall, client, STREAM_ID)
@dogukan ping :slight_smile:
Hi @mhelmrei, sorry for the late reply.
With v3, we updated our data extraction workflow and introduced a new concept called DataObjects. So it’s expected that you’re not seeing native Revit Wall.
This article could be a further read :slight_smile:
Hi @dogukan,
I went through the intro—really exciting stuff!
Are there any examples available for how to use the v3 data objects from the GitHub repo?
Thanks a lot!
Matthias
