Revit to Speckle
Hi all, an issue we’re having is that not all of the structural components are successfully transmitting (please see attached snap, of the example Revit project to illustrate). Has anyone come across this before?
Revit 23, Speckle 2.13.4, Revit Connector 2.19.3.
Cheers!
Hi @jim! :slight_smile:
Apologies for my delayed response. Using your specs (Rvt 23, Connector 2.19.3 and selection on the 844 objects), I’ve tested it on my end and wasn’t able to reproduce the error, .i.e. the whole model sent through fine:
Although good news for me, this won’t be helping you :laughing:
Next steps:
  • Would you mind sharing the Revit logs with me: %appdata%\Speckle\Logs\
  • I know it sounds a little silly, could you try send again? Maybe with a different selection mode (“everything”)?
Cheers! :slight_smile:
Hey @jim. Checking in on how it went your side?
Thanks Bjoern, still to revisit, but will share logs / try fiddling around with the export settings.
I’ll relay any findings here!
Cheers!
