Revit Room Export Issue: ArgumentNullException with Speckle Exporter from Linked Models
I have the same issue with a S&C and a Fitout model after separate room export.
Rooms are in the Arch models, I am the BIM support for electrical engineers. I can’t merge the models in Revit every week, so I use two separate visuals which works fine, but hard to understand.
Unfortunately it seemes to me, Speckle exporter does not support exporting rooms from a linked file yet!
export
@gokermu Please let me know if i am mistaken with the linked export!
Hi @Zsolt_Megyesi,
It appears that the error in the image confirms that rooms are not being exported from linked models. Could you please share the source model with us? You can send a DM. We will review it to find a solution. Please note that this fix will likely only be released for the next-gen Revit connector.
Thank you!
Hey @Zsolt_Megyesi ,
This has been fixed as part of the next-gen Revit connector.
3 posts were split to a new topic: Visual colors by Tooltip, not Color By input
