Is solid rebar from Revit to speckle suported?
Am trying to export rebar project from Revit to blender using speckle. I can Only see lines both in speckle and blender. Am I missing something or its not supported?
Hi @Skillmax ,
Rebar is only sent with its centerlines as the display value, so what you are seeing is correct. We don’t send the solid meshes of the rebar currently due to performance limitations in our viewer for large rebar models, but it’s understood that some users would prefer to have the solid geometry instead for rendering workflows.
