Hi there,
I got a revit model that is a survey based on a point cloud.
i can send to speckle the revit model separately and the point cloud separately.
but when i try to send them both i get a scale error.
the point cloud is scaled with 3.18… in revit but it seems it does not reflect that scale in speckle.
How/where do you plan on using this pointcloud? This may help decide if it makes sense to send pointclouds already scaled or to send the original geometry with a scaling factor attached.
Hi, the use for now is to use speckle as an online viewer for al the stakeholders in a project.
from an interoperability point of view, if the point cloud is scaled in revit, then i would like speckle to retain that particula value, so that when i receive data from speckle into a new revit file it would retain the scale factor, so that one could replace the received data with the original point cloud data, or even with a more dense point cloud data. than the scale factor and reference point would be crucial to overlaping the data correctly.
A note on this: we currently don’t support receiving pointclouds in Revit, but this may be added in the future
