Revit Linked models no being exported
Hi everyone,
I’m working on creating a workflow that involves sending multiple linked models to Speckle. Despite adjusting various export options in the Advanced Settings and trying different combinations, I’m encountering an issue where no geometry is being exported.
While the links appear in the stream, they’re showing up as analytical elements rather than actual geometry.
Has anyone encountered this before? Any tips would be greatly appreciated.
Thanks, Ricardo
This is the stream im publishing from revit
https://app.speckle.systems/projects/63f0f8a0d2/models/b45ec9227b
regards
Ricardo
Hola RIcardo!
Unfortunately this is a known limitation, I believe it should be soon supported in the v3/next-gen connectors we’re working on though: Introducing Next-Gen Connectors
Hi @Ricardo_Zepeda,
We have enabled multiple instance Revit linked models with next gen Revit connector. It is available here.
Nice! will try on residential projects to get planning data to power bi Thanks!
