Revit Elevations to AutoCAD
I am just wondering if it is possible to send Revit Elevation Views to AutoCAD via Speckle?
Hi Simon,
Speckle is designed to work with 3d data, so while you can select any view when publishing your model form Revit, the whole 3d element set visible in the view will be send & then received in AutoCAD.
ok, makes sense. Thanks
