Revit Dynamo Speckle "System.IO.FileLoadException Dynamo has detected a conflict with a dependency..."
Hello!
I made a Speckle-Dynamo file that all my coworkers use every couple of weeks. Within the past few weeks, after making no changes to the Dynamo file, as far as I know, they all have started to receive this error when they click the “Receive” button. an example of the stream input is :
Speckle
There is also these two new errors upon opening the file. How can I fix this?
Here’s what it looks like zoomed a bit out :
Hey @j-mcallister welcome to the forum!
Feel free to Introduce yourself :person_gesturing_ok: if you’d like.
The firsts things I would suggest are:
  • reinstall the dynamo and revit connectors from Manager
  • ensure all the installed connectors are on the latest available 2.15 or above version
If this doesn’t solve it, then it could be that another revit or dynamo addin recently installed might be conflicting - can you think of anything?
that first suggestion worked! thank you :slight_smile:
(tho the connectors are a 2.15 version, but still worked!)
