I’m new to this forum and to speckle and walked into my first issue.
When opening two Revit projects at the same time Revit gives an unrecoverable error and just shuts down.
I did some troubleshooting yesterday via de steps in this thread from autodesk:
When I got to disable add-ins I uninstalled the speckle for Revit add-in and then things worked again as it should. This morning I reinstalled speckle for Revit because there was a new release yesterday but it crashes again when opening 2 projects at the same time.
So my guess is that it is an issues with Speckle.
Is this a known issue? If yes, is there a workaround or a solution?
Sorry for this and thanks for reporting! It’s an old bug that unfortunately slipped in the latest release.
It’s already been re-fixed and you can install version 2.6.4 of the Revit connector to keep using Speckle.
When I’m trying to install manually I get this error:
But as far as I know I have al the rights and normally I can install everything. It gives me this error for all Revit versions that I have installed (from 2019 to 2022).
