We are using a dedicated Speckle server hosted in an internal data centre with the same set-up as the Speckle online server we were using with success before. Using the Revit connector to push model elements we are getting these warnings, but now have consistent issues uploading a specific file and it usually fails to send. Total children count (when it does succeed in being sent) is 24608. File size is about 540MB
When it fails, this is the log that we get and wonder if there is something here that could tell us what is going on?
'Oreference not set to an instance of an object.
at System.Object.GetType()
at Objects.Converter.Revit.ConverterRevit.CurveToSpeckle(Curve curve, String units)
at Objects.Converter.Revit.ConverterRevit.TryGetLocationAsCurve(FamilyInstance familyInstance)
at Objects.Converter.Revit.ConverterRevit.ColumnToSpeckle(FamilyInstance revitColumn)
at Objects.Converter.Revit.ConverterRevit.ConvertToSpeckle(Object object)
at Speckle.ConnectorRevit.UI.ConnectorBindingsRevit.<SendStream>d__9.MoveNext() in C:\Users\circleci\project\ConnectorRevit\ConnectorRevit\UI\ConnectorBindingsRevit.Send.cs:line 85
The input point lies outside of Revit design limits.
Parameter name: origin
at Autodesk.Revit.DB.Plane.CreateByOriginAndBasis(XYZ origin, XYZ basisX, XYZ basisY)
at Objects.Converter.Revit.ConverterRevit.BoxToSpeckle(BoundingBoxXYZ box, String units)
at Objects.Converter.Revit.ConverterRevit.ViewToSpeckle(View revitView)
A task was canceled.
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Speckle.Core.Transports.ServerTransport.<HasObjects>d__67.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at Speckle.Core.Transports.ServerTransport.<ConsumeNewBatch>d__59.MoveNext()
Object reference not set to an instance of an object.
at Speckle.Core.Serialisation.BaseObjectSerializer.WriteJson(JsonWriter writer, Object value, JsonSerializer serializer)
at Speckle.Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeConvertable(JsonWriter writer, JsonConverter converter, Object value, JsonContract contract, JsonContainerContract collectionContract, JsonProperty containerProperty)
at Speckle.Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeValue(JsonWriter writer, Object value, JsonContract valueContract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerProperty)
at Speckle.Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.Serialize(JsonWriter jsonWriter, Object value, Type objectType)
at Speckle.Newtonsoft.Json.Serialization.JsonSerializerProxy.SerializeInternal(JsonWriter jsonWriter, Object value, Type rootType)
at Speckle.Newtonsoft.Json.JsonSerializer.Serialize(JsonWriter jsonWriter, Object value)
at Speckle.Newtonsoft.Json.Linq.JToken.FromObjectInternal(Object o, JsonSerializer jsonSerializer)
at Speckle.Newtonsoft.Json.Linq.JToken.FromObject(Object o, JsonSerializer jsonSerializer)
at Speckle.Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeConvertable(JsonWriter writer, JsonConverter converter, Object value, JsonContract contract, Json'
