Revit Connector Error with account
My revit connector lost connection to my accounts and gives error : could not get projects !
and i cant send or recieve anything from speckle
Revit2023
connector 2.19.1
Hi @Ahmed_Hafez,
Welcome to Speckle!
Can please open the Speckle Manager and make sure you are using the correct Speckle account.
Make sure you can see the account inside the Revit Speckle window.
Let us know how it goes.
Here is some more information on what URLs need to be accessible. Maybe you’re using a VPN or a corporate network?
I tried resign in but it gives error : failed to create account from access code and challenge
Hey @Ahmed_Hafez,
Are you using any firewall or VPN?
  • Make sure the server address is not blocked by a corporate firewall, proxy or VPN, by either trying to access it via a different network (eg mobile network) or by contacting your IT department.
If not, please go here in your folder %appdata%\Speckle\Logs\Manager2 and send us your Log files.
I sent you a Google Drive link to the email you use on the forum. Please upload the log files there.
