Wadao
I am experiencing a problem with the Speckle 2 for Revit add-in, which fails to load in Revit and throws a System.TypeLoadException error. Here are the details of the issue:
Revit Version: 2022 and 2023 atleast
Speckle Connector Version: 2.17.1.13226
Error Details:
- The error states:
Could not load type 'Speckle.Core.Helpers.Open' from assembly 'SpeckleCore2, Version=2.17.1.13226, Culture=neutral, PublicKeyToken=null'
- This suggests that there might be an incompatibility with another add-in I have installed, but I am not sure which one.
I suspect that another add-in could be causing this conflict. Can someone provide guidance on resolving this error? If needed, I can provide additional system details or logs.
Thank you for your assistance!
Hi @JaakkoRamboll, and welcome to the forum! We’d be happy to help, but ideally we’d look at things vs the latest release which is 2.20.3 (vs. your current one of 2.17 - by our standards, you’re three major releases behind).
Would you be able to upgrade to that and give it another go?
Okey updated to latest versions. Speckle connector and In my project I am also using latest version library 2.20.3.
I’m facing an issue with System.MissingMethodException in my project due to conflicting versions of HarfBuzzSharp. My setup is as follows:
Project Libraries:
LiveChartsCore: Uses
SkiaSharp, which depends on HarfBuzzSharp version 7.3.0.
Speckle UI (via Avalonia): Appears to reference
HarfBuzzSharp.Buffer.GetGlyphInfoSpan() which may be from a different or incompatible version of HarfBuzzSharp.
Error Details:
- Exception:
- Message:
Method not found: 'System.ReadOnlySpan<HarfBuzzSharp.GlyphInfo> HarfBuzzSharp.Buffer.GetGlyphInfoSpan()'
Note:
Speckle is using HarfBuzzSharp fileversion 2.8.2.1
LiveCharts is using fileversion 7.3.0.0
