Tl;dr Speckle instances (be it revit families or rhino/autocad blocks) will be received as collection instances in blender. These are special type of empty that instances a entire collection of objects, as such are a close match to the same concept in Speckle and other 3d apps.
These aren’t the easiest to edit inside blender, so i recommend you checkout the receive option to receive Speckle instances as linked duplicates, which behave more like standard blender objects.
