Hi all,
I’m trying to extract Revit Area Elements and push to Speckle but I can not seem to filter by that category. I see in this list these Area elements should be supported Supported Elements | Speckle Docs but do not see that category as an option to filter by, nor can I manually select these elements. Any hints? Rooms and HVAC Spaces and other elements get published fine, just not Areas.
I’m running the most recent Speckle Revit Connector on Revit 2020, pushing data to a v2 Speckle server created from most recent Docker image, running inside our firewall on an AWS EC2. I have also tried this on the public Speckle.xyz server and a DigitalOcean server I set up.
thanks,
-matt
