Revit (24) crashes when loading project
Hello Specklers
I just updated the Revit connector and get a crash when opening a project.
Crash report attached. I have a few other plugins installed, will try disable them to see if that that makes a difference.
Hey @ChrisT ,
Sorry about this and thanks for the report!
Can you please confrim:
  • the version of Specke Connector you installed before the crash
  • if installing a previous version it works fine
PS
FYI we’ve release in beta a new (v3) version of our connectors whihc is much more performant and stable: Speckle Next-Gen Connectors
hey @teocomi apologies, I never replied to this all that time ago! I solved the issue by disabling some plugins, I wish I now did that systematically, so I could tell you which one was causing the issue! One of them was pyRevit
