After updating from 2.8 to 2.9.2 we get errors like this:
They appear when sending some elements to Revit.
The Revit clients are updated today.
Where should I start to resolve this problem.
Cheers
Bernhard
Cheers
Bernhard
Hi @bernhard - was this model working in 2.8?
It’s likely that you’re bumping into the limits on the maximum upload size of 100Mb: speckle-server/app.ts at a537d34dcc43dc81f4701942e1352e4860437668 · specklesystems/speckle-server · GitHub
Iain
Hi iainsproat,
according to the guys that are really working on it, it worked in the old version.
And it actually works when uploading to speckle.xyz
They talk about “relatively small projects”, so I don’t think it is an issue with some 100Mb limit (but I don’t know).
Bernhard
Hi @bernhard, could you privately share that stream on xyz with us? we can look if any specific geometry topologies got out of hand. I suspect there may be some crazy meshes in there.
That response might also come from having an individual object larger than 10mb. I remember @iainsproat and @gergo we bumped that to 25mb in the past for our deployments - which could explain the “but it works on speckle’s computer” part…
