Hi guys,
I added a stream to a Revit document in the past. But now I want to remove it. Is there any way I can do that?
Hi guys,
Hey @gokermu, I’m using Rhino but Revit should work just the same:
If you’re using DUI, then just click the stream name and you’ll see the remove option at the bottom of the panel that will appear
If you’re using DUI2, you’ll see the option in the context menu
Thanks @AlanRynne. This is just what I want.
