I am running speckle locally from docker compose. All the services are running without any error.
But when I login with the admin userId and Password mentioned in the docker file, I get error. “Failed to fetch”
When tried to register or forgot password, I get same error.
Log:
entry.DMzWazSt.js:9037 WebSocket connection to ‘ws://127.0.0.1:8080/graphql’ failed:
This error is often encountered when the CANONICAL_URL, NUXT_PUBLIC_API_ORIGIN, or NUXT_PUBLIC_BASE_URL values are misconfigured in your Docker compose file.
You may wish to search our forum here at https://speckle.community for similar threads which may help you find an answer, as this issue has been encountered by others before.
