Received stream not showing in Grasshopper
Hi, first time user here!
I’m using the Grasshopper connector, and am using the receive component to receive a stream of the default model already existing in Speckle when signing up (base design - Spockle's First Project | Speckle)
The model is apparently received by Grasshopper, see the picture below, but nothing shows up in the Rhino viewport. Am I missing something?
I’ve tried it on both Rhino 7 and 8, using Windows 11.
Happy for some support!
Hey @Spockle, (btw I love the name)
Welcome to Speckle!
When you receive a Project in Grasshopper you receive a Speckle Collection of objects.
You need to use the “Deconstruct” component to deconstruct the Speckle Objects/Collections.
Thank you for the solution :smile:
