Receive timeouts from app.speckle.systems
Hi folks.
We’re getting the following timeouts on a Receive() call to app.speckle.systems.
 System.Net.Http.HttpRequestException: Response status code does not indicate success: 524 (<none>).
    at System.Net.Http.HttpResponseMessage.EnsureSuccessStatusCode()
    at Speckle.Sdk.Transports.ServerUtils.ServerApi.ResponseProgress(HttpResponseMessage childrenHttpResponse, IProgress`1 progress, CbObjectDownloaded onObjectCallback, Boolean isSingle)
    at Speckle.Sdk.Transports.ServerUtils.ServerApi.DownloadSingleObject(String streamId, String objectId, IProgress`1 progress)
    at Speckle.Sdk.Transports.ServerUtils.ParallelServerApi.RunOperation(ServerApiOperation operation, Object inputValue, ServerApi serialApi)
    at Speckle.Sdk.Transports.ServerUtils.ParallelServerApi.ThreadMain()
    at Speckle.Sdk.Transports.ServerUtils.ParallelServerApi.DownloadSingleObject(String streamId, String objectId, IProgress`1 progress)
    at Speckle.Sdk.Transports.ServerTransport.CopyObjectAndChildren(String id, ITransport targetTransport)
    at Speckle.Sdk.Api.Operations.RemoteReceive(String objectId, ITransport remoteTransport, ITransport localTransport)
    at Speckle.Sdk.Api.Operations.ReceiveImpl(String objectId, ITransport remoteTransport, ITransport localTransport, IProgress`1 internalProgressAction, CancellationToken cancellationToken)
    at Speckle.Sdk.Api.Operations.Receive(String objectId, ITransport remoteTransport, ITransport localTransport, IProgress`1 onProgressAction, CancellationToken cancellationToken)
The 524 response status is the timeout response from Cloudflare. The BATCH_SIZE_GET_OBJECTS is set to 10,000 objects per HTTP request in ServerAPI.cs. It appears that this isn’t returning in time before the Cloudflare 100s timeout threshold.
There currently isn’t a way to change this batch size to something smaller to avoid this. Ideally, the ServerTransportFactory.Create() in the SDK would be changed to allow setting this to a different value. An approach might be to have the constant as MAX_BATCH_SIZE_GET_OBJECTS with another value for a sensible minimum. The Create() function could then allow the setting of batch_size between these values if required.
This is currently a show-stopper for us. If there is a different way of avoiding this problem it would be great to know.
Tim Lewis.
Hi @timlewis
Is it possible for you to share a link to the model with me (via a direct message to stay confidential)?
I’ll try and pull some server logs to see if I can see anything.
I did some searches through our logs, I think I have all the info I need to investigate @timlewis, no need to send any links.
I’ll run some experiments and coordinate with the team.
Thanks for jumping on this one so promptly Jedd. Really appreciate it.
Hi @timlewis
Just a quick update; we’re still working on it.
We’ve identified it to be a problem on our server side, that affects retrieving the object data of large models. We can consistently reproduce with some of the data on your project.
We’ve implemented a change already that we were hoping might solve this problem, however it were not sufficient and the problem appears to persists…
We’ll continue to search for a solution, I’ll let you know as soon as we have any updates.
If this is blocking you in the mean time; I might be able to suggest some some work-arounds that should avoid running into this problem.
If you’re interested; You might find success re-publishing the model through a different route. E.g. one of our desktop connectors, or via IFC files.
Hi @timlewis,
Earlier today, we pushed an update that hopefully should address the issue you’l reported with large Navisworks models.
I believe the fix only applies to new versions, so you will have to re-upload any affected models.
