Receive Bug: Jagged faces on some BREP geometry when receiving Rhino2Rhino
Hello again
I was running some colab tests today and noticed some Geometry weirdly “breaking” when receiving Rhino 2 Rhino. Building edge s that should be “streight” seems to be broken up in a zigzag pattern. Curious that even though each story is a separate brep they are being handled the same way. Most geometry is fine with maybe 1 or two occasional “kinks” showing up. I attached an image of the most extreme example that i have come across.
I am using Rhino 8, connector verson 2.20.0
Any chance you can share the rhino file with us?
This will help us try and recreate the problem
Hey Jedd! Upon further inspection the problem was in the rhino modell being sent. There was a mixup with the rhino files. Feel free to delete this post
Ah ok,
I looked at the screenshot and did not find the problem.
OK, Antialiasing isn’t top notch quality but for me it looked
like the facade itself is jagged - not the rendering.
:slight_smile:
