REBAR Visualization
Can you tell me, how can I see the rebar in my SPECKLE space ?
I only see lines but I want to see the 3d Rebar.
Hi Javier,
This is not currently supported, as it can be very heavy geometry.
Can you tell us more about why you need to see the 3D rebar elements?
cc @clrkng
Hi Mateo.
I work in a construction company. It is very usefull to see this 3d elements because I am implementing the use of Speckle as a principal CDE for BIM and my coworkers control the Rebar of the structural elements.
Hey @JAVIER_ARENAS
Good news - rebar visualization is in the latest release of the Next-Gen connector. By default, the displayValue of rebar will send as the simplified centreline representation:
You can, however, toggle Send Rebars as Volumetric which will send the rebar as the extruded volumetric represenations:
Cheers,
Björn
