Hi Speckle and Structural Community,
Thanks for the meetup. As mentioned, here is a mix of comments or questions that I have been writing down while I’ve been using the structural object model in combination with SAF. It was a bit too much (and perhaps too detailed) for the meetup.
Visualization:
- Are there any plans for or thoughts about adding (symbolic) visualisation of structural model objects in the online 3D viewer or Grasshopper (for supports, members, loads, joints, results, cross sections…)?
Also for elements it could help to understand their final position and orientation (taking into account offsets, eccentricities, alignments, rotation angles, orientation nodes, axes, …).
Missing properties:
- If for a specific app there are one or two properties missing in a Speckle object which are not always needed (e.g. the fillet radius of a tube section, that needs to be defined in SAF), is it better to add them dynamically (in the member dictionary of the base object) or to make a new app-specific derived class in which these properties are added (better defined, but might lead to a lot of classes in the end)?
Geometry classes:
- It would be useful to have methods for common geometry operations to deal with local coordinate systems of elements (also see here): vector length, cross/dot product, norm, line direction, …
Element1D class:
- baseLine property of Element1D should accept a general ICurve instead of a Line; curved or multisegmented beams are imaginable.
- orientationNode: if specified, this should overrule the Axis property, correct? Since Axis and OrientationNode both handle the Local Coordinate System of an object, better to only store one of both and to let the other property be automatically derived from the first. Would you agree?
- better to use an OrientationPoint instead of OrientationNode, as only the XYZ coordinate of this object is relevant?
- another example of duplicate data in properties is baseLine, end1Node, end2Node and topology. Better to for example scratch the end nodes and only use topology (and rename this property to “nodes”)? It will certainly simplify the amount of cases to be considered by converters.
- Property1D.offsetY and offsetZ values duplicate Element1D end1offset and end2offset?
- When selecting Element1D objects in the Speckle web viewer, you select the Line object, not the Element1D object, making it difficult to browse their properties; are there plans to correct this?
Axis class:
- I find axis confusing as a name, something like CoordinateSystem would more clearly represent what it is. Perhaps this is just me?
- it is currently defined by a plane, not 3 vectors; when set for a 1D element, should this be the plane normal to the element in which the profile is drawn (feels most intuitive; the main axis of a plane tends to be its normal) or should the axes correspond to the local axis convention of a beam (which makes most sense; X along the length of the element, Z points up and Y points right)?
AnalysisModel class:
- what’s the logic behind the choice of properties, and where should each object type be stored within this model object?
- for example, should the Loads property only contain loads, or also LoadCases, LoadCombinations, …?
- restraint doesn’t exist as separate object in SAF, but is always defined in combination with geometry (points, lines, …); the restraints property of the AnalysisModel in this case is thus not useful. What’s the added value of adding it separately?
Loads: common need for a ThermalLoad object?
Enums:
- Currently seem very specific for GSA, and it is not always to find a one-on-one mapping with SAF:
- e.g. Speckle LoadType enum vs. SAF Load Type enum > how would you map these?
- to make them more open to alternative classifications or definitions, perhaps it is useful to also have a “Other” or “NotDefined” option for each Enum? Currently there are some Null or Undefined or NotDefined options existing, but it might be better to have one for each enum with a consistent name.
Some ideas/questions specific for Grasshopper (as this is a powerful way to define parametric structural models):
Is it possible to add a custom string representation to Speckle objects? Or default to “Class name + Name value”. The current one is often not very meaningful for people setting up these models:
would it be possible to manually delete or not show some properties in the ExpandSpeckleObject component (e.g. the ones with no value), as there are often many unused ones?
also for the ExpandSpeckleObject component, would it be possible to match the order of the most common schema inputs in the output parameters to avoid the spaghetti below?
icons in Grasshopper can help navigation and finding the correct schema node. It seems useful to build an icon library (at least for the most common objects) with icons based on namespace + class name:
- to avoid having to create an icon for each schema object, automatically pick the one with the longest name match. E.g. for Objects.Structural.Geometry.Element1D, first try Objects.Structural.Geometry.Element1D, if not existing try Objects.Structural.Geometry, else try Objects.Structural, else take the basic Objects one
That’s all for the moment. Happy to hear your thoughts and discuss!
Kelvin
