Question: Receiving a model Asynchronously at runtime in Unity
I’ve been working on a Unity Project to automatically detect a new version uploaded to a speckle account, and have it automatically receive the model in the unity gamescene.
The listeners work; when a model is uploaded automatically from Revit, it detects it. However, when it tries to trigger the speckleReceiver.ReceiveAndConvert_Async();, the model does not show up in the gamescene. Below is the code.
using System;
using System.Collections;
using Speckle.ConnectorUnity.Components;
using Speckle.Core.Api;
using Speckle.Core.Models;
using Speckle.Core.Transports;
using UnityEngine;
using Speckle.Core.Kits;
using Speckle.Core.Logging;
using Speckle.Core.Models.GraphTraversal;
//edit below this
public class SpeckleSyncHandler : MonoBehaviour
    public SpeckleReceiver speckleReceiver;
    private Client speckleClient;
    private IDisposable subscription;
    private void Start()
        var account = AccountManager.GetDefaultAccount();
        if (account == null)
            Debug.LogError("No Speckle account found!");
            return;
        speckleClient = new Client(account);
        // Listen to Project
        var streamId = speckleReceiver.Stream.Selected.id;
        var subscription = speckleClient.Subscription.CreateProjectVersionsUpdatedSubscription(streamId);
        // Attach event handler to react to new versions
        subscription.Listeners += OnNewVersionReceived;
        Debug.Log("Listening for new versions...");
    private void OnNewVersionReceived(object sender, EventArgs e)
        Debug.Log("New version detected.");
        if (speckleReceiver != null)
            Debug.Log("Data receive and conversion triggered.");
    private void OnDestroy()
        subscription?.Dispose();
        speckleClient?.Dispose();
In the console," Listening for new versions…" , “New version detected.”, “Data receive and conversion triggered.” all appear, but the model does not.
I also tested the code below to see whether Speckle Receiver can function during runtime. After pressing the space button and waiting for 1-2 seconds, the model appeared in the gamescene
using System.Collections.Generic;
using UnityEngine;
public class TestReceive : MonoBehaviour
    private SpeckleReceiver speckleReceiver;
    void Start()
        speckleReceiver = GetComponent<SpeckleReceiver>();
    void Update()
        if (Input.GetKeyDown(KeyCode.Space))
