Hey @SchulzeHagedorn,
That looks correct, did you follow all the steps from the tutorial?
Please let me know.
Hey @SchulzeHagedorn ,
If you are using OneDrive, we have seen cases where there are two Documents folder being present in Windows. Make sure you put the Speckle.mez file under the correct one. If you are not using OneDrive, you can reset your Documents folder using the following guide:
Configuration of the My Documents folder - Microsoft Support
