Very new to Speckle so this may not be possible, but can I send Archicad objects to be converted to blocks in Rhino? For example, multiple windows with identical parameters in Archicad would read as a single block in Rhino.
Hi @MSDCA ,
Archicad objects are currently received to Rhino only as meshes. However, this is already supported in Revit - Rhino workflow where Revit instances are received as blocks so we can make it work for Archicad too.
How do you work with Archicad models in Rhino? What would you do with the blocks? I just want to learn a bit more about your use case so any more details would be appreciated.
2 years later same issues!.. Basically we start with a simple model in archicad that we push to rhino to add much more detail for visualisation purposes. I think the issue goes beyond this into workflows to be honest, but interested if there’s been any development around this
Hey @MSDCA ,
To be transparent: this isn’t something we’ve built, and it’s not currently on our roadmap. We just haven’t seen enough demand to prioritize it over other work.
