Question: How can I control transparency/visibility in Viewer?
When I tried to transfer all the project data from Revit to Speckle Viewer, I noticed that all the rooms are shown as solid geometry and it is not possible to see the actually geometry.
I’m using a locally deployed version from Github. Is there a way to customize that? Like in the image, the big flat gray box is not a real geometry but the space a roof element takes.
And also, when I tried to click the isolate on the right, it only showed me the outlines. Is there a way to configure to make the rest of the geometries invisible?
Thanks in advance!
Have you tried with the hide button on the right?
You can also use filters to color object by a specific property:
viewer
