Hi , Is there any query to select particular object in speckle viewer.
Yes, there are several possible ways to go about it. If you can give me a few more details about what you need to do with said objects I’ll gladly provide more guidance
Cheers
I need to select particular object like room stairs etc using object id and camera view should be from front. like this
You can use selectObjects(objectIds: string[])
to select any object. Regarding controlling the camera there are the setView
and zoom
methods. Here is a complete example
viewer.selectObjects(['objectId'])
viewer.setView('front')
viewer.zoom(['objectId'])
By defaults this animates the camera towards that position. If you don’t want it to animate, setView
and zoom
have an optional transition
argument which you can set to false, disabling camera animation.
For various such operations please feel free to checkout the viewer documentation
Cheers
Can you share the stream you’re working on and the object id you’re using? On my side everything works fine
would you please share screenshot .
