Hi
I have a client that just has started a Revit 2020 project. (I don’t know why they already moved to 2020 )
Is speckle running at Revit 2020 and dynamo 2.1?
Thanks.
// Lars
Hi
Thanks.
// Lars
Hello @Lars_Olesen! Just today, on the slack channel, this got asked:
It’s late here hence the brutal image paste, my answer there is the best i can think of…
RE Dynamo you could try copying the speckle dynamo folder form %appdata%\Dynamo\Dynamo Revit\2.0\packages
to %appdata%\Dynamo\Dynamo Revit\2.1\packages
Thanks.
It works fine for me
Have a nice weekend.
Dynamo 2.1 has been added to the installer, forgot to post an update here…
I tried to open the revit client after moving the speckle revit folder from 2019 to 2020 in
\ AppData \ Roaming \ Autodesk \ Revit \ Addins \ 2020, it didn’t work.
Hello @bjorn! welcome to the speckle forums
We’ve haven’t tested speckle revit with 2020 yet, so I believe it won’t work. We will add this to our backlog; nevertheless speckle should work inside dynamo (inside revit 2020).
Hey @bjorn , we’ve added support for Revit 2020 and 2021 in the latest release, go and grab it if you haven’t done so already
